Need Help With SD Card Recovery On Mac After Deleting Files
I accidentally deleted important photos and video files from my SD card while using my Mac, and I need help figuring out the best way to recover them. The card had personal files I haven’t backed up anywhere else, so I’m looking for safe SD card recovery tips for Mac before I make things worse.
I ran into this with a Sony SD card on my Mac. First thing, don’t treat it like a lost cause yet.
Most deleted files on SD cards are removed from the file table, not wiped off the card. The data often sits there until new shots overwrite it. That’s why recovery apps still find stuff.
If you want the easy route on Mac, I’d start with Disk Drill. I’ve also used UFS Explorer and R-Studio, but Disk Drill felt less annoying to work through when I needed results fast. Setup took me a couple minutes. Scan results were laid out cleanly. Previews loaded without much fuss. It also picked up RAW camera files, which mattered for me.
The preview feature is the part I trusted most. If a photo preview opens fine during the scan, there’s a decent shot the recovered file will open fine too. I used that to avoid restoring a pile of junk.
A couple things matter more than people think:
  • Use a proper SD card reader
  • Don’t leave the card in the camera for recovery
  • Skip flaky USB hubs
  • Keep your Mac awake until the scan ends
  • Restore files to your Mac’s SSD or another drive
  • Don’t write anything back to the same SD card
If the card got formatted, I still wouldn’t panic. A quick format often clears indexing info and leaves the file data untouched for a while. I’ve recovered files after format jobs before. Not every time, but enough times to take it seriously.
Where people wreck their chances is pretty predictable. They keep shooting on the card. They format it again. They run random “fix” tools before trying recovery. That’s where things go sideways.
What I’d do, step by step:
  1. Stop using the SD card right now
  2. Put it in a card reader and connect it to your Mac
  3. Install and open Disk Drill
  4. Run a full scan on the card
  5. Let the scan finish, even if it feels slow
  6. Preview the files before restoring them
  7. Save recovered files to your Mac or a different external drive
If you want a free option, PhotoRec is the one I’d mention first on Mac. It works. I’ve seen it pull files other tools missed. But it’s not friendly. Keyboard-driven, rough interface, and recovered files often come back with broken names and no folder structure. You sort the mess later.
One more thing. Check your backups before you spend half the night scanning. I’ve seen people go into panic mode, then find the photos were already sitting in iCloud Photos, Lightroom, Google Photos, or Dropbox. Saves a lot of time if your stuff had sync turned on.
Stop using the SD card now. Every new write cuts your odds.
I agree with @mikeappsreviewer on one point, file previews matter a lot. I disagree a bit on starting with the first recovery app you see. My first move on Mac is to make a byte-for-byte image of the SD card, then scan the image. If the card starts glitching, you still have one clean copy to work from. On macOS, pros often do this with Disk Utility, dd, or a cloning tool. It takes longer, but it saves you from re-reading a dying card 5 times.
If you want the easiest Mac route, Disk Drill is still a solid pick for SD card recovery on Mac. It handles deleted photos, videos, and a lot of camera file systems well. If Disk Drill misses folder names or dates, then try PhotoRec after it. I know @mikeappsreviewer mentioned PhotoRec as a free option, but I’d use it as a second pass, not first. It tends to dump files into a huge mess, and sorting 2,000 clips is painfull.
A few things people skip:
  1. Check Trash on the Mac, sometimes imported files were deleted from Finder, not the card itself.
  2. Check Photos app imports.
  3. Look in DCIM and hidden folders before scanning.
  4. Run First Aid only if the card is mounting weirdly, and only after imaging it.
For photos, recovery rates are often decent if no new data hit the card. For video, larger files fail more often if partly overwritten. That part sucks, but it’s true.
If you want a short visual guide, this SD card recovery steps for Mac and camera photos is easier to follow than most posts I’ve seen.
I mostly agree with @mikeappsreviewer and @nachtdromer, but I would not jump straight into trying a bunch of recovery passes on the physical SD card if these files really matter. Every extra read on a sketchy card is a gamble. If the card still mounts, make an image first, then work from that image. That part gets skipped a lot.
Also, before going deep into recovery, check the dumb stuff because sometimes the “deleted from SD card” story turns into “actually deleted after import.” Look in Finder Trash, Photos imports, and any cloud sync folder on your Mac. It sounds obvious, but panic makes ppl miss obvious things.
If the files are truly gone from the card, Disk Drill is probly the most Mac-friendly place to start. Not because it’s magic, just because it handles SD cards, deleted photos, and video recovery without making you fight the app. I’d use previews to judge recoverability, then recover only the files that actually open. For a more practical walkthrough, this Disk Drill recovery guide for deleted SD card files on Mac is easier to follow than most written reviews.
One thing I slightly disagree on with @nachtdromer: I usually avoid First Aid unless the card is having mount errors. If you ran delete by accident and the card is otherwise fine, recovery first, repairs later. “Fixing” a filesystem can sometimes change what recovery tools can still see.
If Disk Drill misses some video files, then yeah, try a carving tool after that. But start with the least destructive route and stop using the card completley.
