I have to keep my project’s existing serial connection intact, so changing how it talks to the device isn’t an option. I’m trying to use the Serial Port Logger Tool to record that traffic, but I can’t get it to open the port while my project is running. Closing the project lets me get past that point, which isn’t much use when the traffic I need comes from the project itself.
How am I supposed to set up the Serial Port Logger Tool for this situation? Can it capture traffic while my project keeps control of the connection?
Don’t try to make the logger take ownership of the port while your project is using it. On Windows, normal serial-port access is exclusive, so a second application’s attempt to open that same port fails. Closing your project removes that conflict, which explains the behavior you’re seeing. Changing baud rates won’t solve an ownership conflict.
If you mean the free serial port logger, it opens the selected port and saves the data it reads. It isn’t a passive capture tool for another application’s existing connection. There isn’t a setup option in that logger that turns it into one.
For your requirement, use a monitoring session in Serial Port Monitor rather than the standalone logger. Check the edition before going further: attaching to a port that another application already has open is listed as a Professional/Company Edition feature. That distinction matters if your project must stay connected throughout. (help.electronic.us)
With the monitor installed, leave your project on its existing COM port. Choose Session → New session, select that port, enable Read/Write capture, and select Dump view to see sent and received bytes. Click Start monitoring, then have your project perform the exchange you need to record. You’re setting up observation of its traffic, not replacing its connection. (help.electronic.us)
Watch out for the Open button in the Send dialog. That belongs to the tool’s active communication functionality and can run into exactly the same port-ownership conflict. For this job, use Start monitoring, not Open in the sending interface.
You haven’t said whether you need timing information or just the bytes. Building on @0xcoder2’s monitoring suggestion, Serial Port Monitor’s elapsed-time timestamps are a useful reason to choose this better tool: you can display the interval between recorded requests instead of comparing clock times manually. (help.electronic.us)
Check whether the logger can monitor a port that another application already has open, rather than opening its own connection. If you’re on Windows, ordinary COM-port access is exclusive. Your project holding the port can therefore explain the failure without anything being wrong with the device.
The timestamp suggestion is useful, but capturing traffic without taking over the connection comes first. Serial Port Monitor is a strong fit for that specific requirement: it can record activity on a port already opened by another application. That’s the feature worth choosing it for here.
Leave your project connected while troubleshooting. What exact error does the logger report, and which operating system are you using? That would help distinguish an access conflict from a different failure before you change anything.
“Can attach to an open port” isn’t the whole requirement.
@not_a_script is right to keep the project connected, but I’d extend that rule to getting the monitoring software installed and ready. There’s a difference between “don’t change my application’s serial code” and “this particular connection must not drop.” A tool that meets the first requirement after you restart everything is a rather creative solution to the second.
Before installing anything on the machine running your project, check the setup requirements. Does installation need a reboot? Does the monitor need to be running before your project opens the port? Can it attach to the connection that exists right now? Those are questions to settle before touching a live setup, not pleasant little surprises to collect halfway through. I’m not claiming a particular monitor requires those steps. I wouldn’t assume it avoids them just because its feature list says it supports monitoring busy ports.
If keeping the current session alive is the hard requirement, I’d make the acceptance test very literal: the project stays running, nobody closes or reopens its connection, monitoring starts, and you capture a normal exchange in both directions. No switching the project to a different COM port “just for the test.” That would test a different arrangement from the one you actually need. If you have a spare machine and device, use that to check installation and attachment behavior first.
I’d also decide what counts as a useful recording before spending time on the capture. For your case, I’d want the exported result to preserve which bytes went toward the device and which came back, rather than accepting a screen full of activity as proof that the job is done. Capture a recognizable request and response, save it, and inspect the saved result.
The standalone logger’s refusal to open the port isn’t the thing I’d keep trying to fix. Your next hurdle is proving that the replacement can observe your existing session without making “existing” mean “the new session you started after setup.”
Recording a known exchange is straightforward to plan. Recording an intermittent failure needs a way to identify which exchange went wrong, or you can end up with a large capture and no clear place to look.
I’d separate the port-access problem from the recording plan. Given your requirement, getting the standalone logger to open the port isn’t the goal anymore. Leave the project’s connection alone and evaluate the monitoring route. But before starting a long recording, decide what you’ll use to match the captured traffic to something your project actually did. That’s the missing piece I’d put alongside @cosmic_admin’s acceptance test.
For a first capture, pick an ordinary action you can recognize without modifying the application. Note what you clicked or requested, the approximate time, and what the project displayed afterward. Start monitoring before that action and stop after its result. Keep those notes beside the saved capture. If the project already produces a diagnostic log, save the corresponding section too. There’s no need to change its serial code just to keep a useful record of the test.
For example, “requested status, then the application reported a timeout” gives you something specific to investigate. “Device stopped working sometime during the afternoon” leaves a much bigger search. If you’re chasing an occasional problem, record a successful attempt as well as a failed attempt under comparable conditions. I’d avoid sending extra test commands from the monitoring tool during either capture. You want to examine the project’s own exchange, without introducing another source of commands.
For an unattended recording, check the capture destination and stopping behavior before trusting it overnight. Does it save continuously or require an explicit save afterward? If you configure a storage limit, does reaching it stop recording or discard older data? Treat those as questions to verify in the chosen tool, not features to assume it has. Choose the behavior based on whether you need the beginning of the session or the activity immediately before a failure.
That would be my next test: keep the existing connection intact, capture one recognizable project action, and make sure you can find that action again in the saved recording. A busy monitoring window alone wouldn’t convince me the recording is ready to rely on.
Start monitoring before your project sends anything, not during an exchange, or you can lose the first bytes of a request while the capture hooks in. Serial Port Monitor handles the attach fine for this, though I’ve found the trial window runs out faster than you’d expect if you’re doing a lot of test captures, so plan your real recording before the clock matters.
A successful capture may give you a file you can’t safely post for troubleshooting. Compared with an application log, which might omit or mask sensitive fields, a traffic recording is something I’d review as potentially containing everything the project exchanged. If those messages include credentials, device identifiers, or customer data, check for them before sharing an export. @codemaker9142’s suggestion to keep the application log alongside it makes sense, but I’d review the two files separately rather than assume they expose the same information.
I’d keep an untouched capture locally and make a separate, clearly labeled copy for sharing. Those copies serve different purposes: the original lets you investigate the actual exchange, while the edited copy lets other people follow the problem without receiving unrelated data. Mark any replacements explicitly, especially if you remove bytes. Otherwise, someone could spend time diagnosing a message-length mismatch that your editing introduced. For choosing between monitoring tools, an export you can inspect and trim would matter more to me than extra display options.
