I’m trying to customize my Mac by adding widgets to the desktop or dashboard, but I’m not sure how to do this. Can someone guide me through the steps or let me know if there’s a way to enable this feature? Appreciate any tips or solutions.
Oh, adding widgets on a Mac is a trip, lemme tell ya. It used to be all nice and simple with the Dashboard feature—remember that? You just hit F12, and voila, widgets everywhere. Calculator, weather, world clock, it was the golden age of Mac customization. BUT NO, Apple tossed that out the window like it was an outdated pizza box. Now you gotta deal with what’s called the Notification Center Widgets. Fancy name, same concept, minus the fun.
Here’s what you do now:
- Click the date/time in the upper-right corner of your screen to open the Notification Center (or swipe in from the right with two fingers if you’re feeling fancy).
- Scroll down to the bottom and hit the “Edit Widgets” button.
- BOOM. A whole widget smorgasbord pops up. There are pre-installed ones like Weather, Stocks (because everyone apparently tracks that), Calendar, Notes, etc.
- Hit the little green-plus (+) buttons to add stuff. You can even drag them to wherever your heart desires.
- Wanna make it all aesthetic? Size options are available too, from “iconic and cute” to “big enough to block half your screen.”
And if you’re dreaming about widgets on the actual desktop like it’s 2008, forget it. Apple’s not giving us that joy anymore unless you download third-party apps like Übersicht or WidgetWall (yes, these exist). But hey, those often come with their own quirks.
Anyway, welcome to the new world of widgets: slightly functional but very much ruled by Apple’s design choices. Enjoy tinkering! Or just… don’t bother—it’s not exactly life-changing.
Widgets on a Mac—it’s like decorating a shiny new apartment, but Apple decides which furniture you get. @ombrasilente covered the basics, but let me throw this wrench in the system: Notification Center widgets don’t really feel like they belong on your desktop, right? Honestly, I miss the old-school Dashboard too. But hey, let’s work with what we’ve got.
If you’re dead set on having widgets directly on your desktop, third-party apps can sort of bring the dream back to life. Check out WidgetWall, like they mentioned, or Übersicht, which lets you place custom widgets anywhere on your screen. I’ve seen some people use Übersicht to create a pseudo-dashboard right on their desktop, complete with stuff like CPU monitors, weather, or their Spotify playlist. Downside? It’s a little clunky, and you might need to fiddle with code snippets depending on how fancy you want to get. Not exactly plug-and-play.
That being said, if you’re not into downloading extra apps, your hands are pretty tied. Apple’s widgets are stuck in the Notification Center prison, and while you can customize their layout and size, they’re not as interactive or fun as they used to be in the Dashboard days. Feels like Apple forgot what customization means—or just made it intentionally ‘Apple standard.’
TL;DR: Apple won’t let you slap widgets wherever you want unless you bring in third-party tools. If that sounds like a chore, maybe just embrace the minimalist vibes and stick to Notification Center. Or maybe switch to Windows… kidding. Sort of.
Use a single “widget hub” app instead of desktop widgets.
- Install MenuMeters, iStat Menus, or Bartender from their sites.
- Add only what you care about, like CPU, RAM, network, battery, calendar, weather.
- Keep everything in the menu bar at the top.
- Rearrange icons with Cmd + drag.
- Hide rarely used icons inside Bartender.
You get quick info with no clutter on the desktop, and setup takes under 10 minutes.
