How Do I Use Ai
I’m new to AI and not sure how to actually use it for everyday tasks like writing, research, or work. I tried a few tools, but the results were confusing, and I don’t know where to start or which features matter most. I need simple advice on how beginners can use AI effectively without wasting time.
Start small. Most people mess up by asking AI to ‘write me something’ and then getting mush.
Use this 3-step method:
  1. Give it a role.
    ‘Act like an editor.’
    ‘Act like a research assistant.’
    ‘Act like a project manager.’
  2. Give it a job.
    ‘Summarize these notes in 5 bullet points.’
    ‘Turn this rough email into a polite version.’
    ‘Find the main arguments in this article.’
  3. Give it rules.
    ‘Keep it under 150 words.’
    ‘Use plain english.’
    ‘List sources.’
    ‘Tell me what you are unsure about.’
Best everyday uses:
Writing:
Paste your draft. Ask for 3 cleaner versions. Then pick one and edit it yourself.
Research:
Ask for a summary first. Then ask, ‘what is missing?’ Then check sources. AI makes stuff up sometimes, so dont skip this part.
Work:
Use it for meeting notes, email drafts, to-do lists, spreadsheet formulas, and first-pass reports.
Bad prompt:
‘Help with my job.’
Better prompt:
‘I manage customer support. Turn these messy notes into a clear update for my boss. 6 bullet points. Mention risks and next steps.’
Features to care about:
File upload.
Web access.
Voice input.
Chat history.
Source citations.
Skip fancy stuff at first. Learn prompting and editing. That gets you 80% of the value, no joke.
Don’t treat AI like a magic answer machine. Treat it like an intern that’s fast, useful, and kinda clueless unless you supervise it.
I partly agree with @yozora, but I’d add this: prompting is not the main skill. Judgment is. Beginners get stuck because they assume the output is either genius or garbage, when most of the time it’s a draft. That’s the sweet spot.
A simple way to start is to pick one repeat task you already hate doing:
  • cleaning up rough writing
  • turning long stuff into short stuff
  • brainstorming options
  • extracting action items
  • rewording awkward messages
Then use AI only for that one thing for a week. Seriously. Don’t try 14 features at once or your brain melts a bit.
For writing, ask it to critique before it rewrites. That works better than hitting “write for me” imo.
For research, use it to map the topic, not to be the final source of truth.
For work, use it on low-risk tasks first. Internal summaries, agendas, draft docs, not legal/compliance stuff unless a human is checking every line.
Features that actually matter to me:
  • decent memory/history
  • easy copy/paste
  • export/share
  • source visibility
  • privacy settings
If a tool is confusing, skip it. Simple beats “powerful” when you’re new. Most ppl overcomplicate this stuff way too fast.
Start with “show me three versions.”
That’s the beginner move nobody uses enough. Instead of asking AI for one answer, ask for 3 different outputs:
  1. safe/professional
  2. simple/plain English
  3. more direct/persuasive
You’ll learn faster by comparing than by chasing the “perfect prompt.”
I slightly disagree with @yozora on one point: if a tool feels confusing, don’t always skip it immediately. Sometimes the confusion is just bad defaults. Spend 15 minutes testing one real task before ditching it.
A practical setup:
  • one chat for questions
  • one chat for writing help
  • one chat for work notes/summaries
Keep those separate so results stay less messy.
For research, ask:
  • what are the main viewpoints?
  • what’s missing here?
  • what would I need to verify myself?
That last question matters a lot.
For writing, paste your draft and say:
  • keep my tone
  • cut 30%
  • point out weak spots first
Pros for ‘’: can improve readability, help organize ideas, speed up repetitive tasks.
Cons for ‘’: can sound generic, miss context, and make you trust weak info if you stop checking.
Best feature for beginners, honestly? Editability. If it’s easy to tweak, you’ll actually use it.
