How To Disable Ai Overview
AI Overview started showing up in my search results, and it’s getting in the way of the links and information I actually want to see. I’ve tried changing a few settings but can’t find a clear way to turn it off. I need help disabling AI Overview so search works the way it used to.
You usually can’t fully turn off Google’s AI Overview with one account setting. Google does not offer a clean global off switch for most users right now. Annoying, yep.
What you can do:
  1. Use the Web filter.
    After you search, click Web. This strips out a lot of extra stuff and shows standard blue links. On mobile, tap the filters row and look for Web. If you do not see it, tap More first.
  2. Add this to your search.
    -type a normal query, then switch to Web
    -or use browser keywords/bookmarks for Google Web search
A direct Google Web search URL works:
Replace your+search with your terms.
  1. Use a browser extension.
    There are extensions for Chrome and Firefox made to hide AI Overview blocks. Search the addon store for things like “hide google ai overview”. Read reviews first, some are jnaky.
  2. Try another search engine.
    DuckDuckGo, Startpage, Kagi, even Bing for some searches. If Google keeps forcing the box in, switching is the only full fix.
  3. Sign out or test another browser.
    Some users report different layouts when signed out, though results vary a lot.
Short version, no official one-click disable exists right now. The best workaround is the Web tab or a custom search URL. If you want, I can give you a one-click Chrome bookmark setup for Web-only Google searches.
There isn’t really a hidden toggle for it, and on that part @byteguru is right. Where I kinda disagree is the extension route being the first thing people should try. A lot of those are half-baked, break search pages, or stop working the second Google changes the layout.
A couple other things to try instead:
  • In Google Search settings, turn off Search personalization if it’s available on your account. It won’t always remove AI Overview, but it can reduce some of the extra clutter.
  • If you’re using Chrome, clear Google cookies/site data and test again. Sometimes Google is just persisting an experimnt or account-based layout.
  • On mobile, using a private tab sometimes gives a cleaner result page than the regular app.
  • If you use the Google app, try searching from a browser instead. The app tends to push more “features.”
  • You can also use a content blocker like uBlock Origin with custom filters to hide the AI Overview section visually. That’s more reliable than random “AI remover” extensions, imo.
So yeah, no real off switch. Best bet is reduce it, hide it, or avoid the app/site version that keeps forcing it. Kinda dumb, but that’s where things are rn.
No real master switch exists right now, so I mostly agree with @byteguru on that part. Where I’d push back a bit is this: hiding it is not always the best long-term move if you still want normal Google behavior without page hacks.
A few other routes that are worth testing:
  1. Add &udm=14 to some Google searches
    This can force a more web-links-focused results view in certain cases. It is not perfect, and Google changes behavior constantly, but it can cut down a lot of the extra search fluff.
  2. Use the Web tab directly
    After searching, switch to Web instead of All. If you do this a lot, make that your habit instead of fighting the default page every time.
  3. Log out of your Google account for search only
    Not just private mode. Fully logged-out search can behave differently from signed-in search, especially if Google is rolling features out by account.
  4. Change your search engine
    Honestly, this is the cleanest answer if AI Overview keeps annoying you. Startpage, DuckDuckGo, or even Brave Search can be less intrusive depending on what you want.
  5. Try a custom search shortcut in your browser
    You can make a search engine entry that sends queries straight to a cleaner results format. That is often less fragile than install-and-pray extensions.
Pros of ’
  • Can improve readability if used for organizing search-related tips or workflows
  • Useful if you want a cleaner reference for repeated fixes
Cons of ’
  • Not actually a switch for disabling AI Overview
  • May not help if Google changes result formatting server-side
So the short version: you probably cannot truly disable AI Overview everywhere, but you can dodge it, reduce it, or bypass it more effectively than just flipping random settings.
