My Android phone has gotten painfully slow over the last few weeks—apps take forever to open, the keyboard lags, and even simple tasks like switching between apps feel delayed. I’ve tried restarting, clearing some storage, and closing background apps, but nothing seems to make a lasting difference. What specific steps or settings should I check to fix a slow Android phone and get it running smoothly again?
Happens a lot after a few months of use. I would go through these in order and test after each step.
Check storage
• Settings > Storage
• Keep at least 10 to 20 percent free.
• Delete big videos, downloads, WhatsApp media, Telegram media.
• Uninstall apps you never open. Social, shopping, games, keyboard themes, etc. -
Remove or replace heavy apps
Some apps slow everything.
Common culprits: Facebook, Instagram, Snapchat, TikTok, Chrome with many tabs, antivirus apps, RAM booster apps.
Try:
• Use Facebook Lite, Instagram Lite if available.
• Use a lighter browser like Firefox, Opera, or DuckDuckGo.
• Delete “phone cleaner” and “RAM booster” apps. They usually hurt performance. -
Check background apps
• Settings > Apps > See all apps.
For each app you do not need in background:
• Tap Battery > Restricted or Optimized.
• Disable “auto start” if your phone brand has that option. -
Clear app cache
Do not wipe everything, target the heavy ones.
• Settings > Storage > Apps
Sort by size.
For big apps: Chrome, YouTube, Instagram, TikTok, Maps, Play Store
• Tap each > Storage > Clear cache.
Avoid “Clear storage” unless the app is misbehaving. That logs you out. -
Tweak animations
This helps a lot on older phones.
• Enable Developer options
Go to Settings > About phone > tap Build number 7 times.
• Then Settings > System > Developer options
Set:
Window animation scale = 0.5x
Transition animation scale = 0.5x
Animator duration scale = 0.5x
If still laggy set them to “off”. -
Update system and apps
• Settings > System > System update.
Install pending updates.
• Play Store > tap your icon > Manage apps and device > Update all.
If phone is low on storage, update only critical apps. -
Check battery health and thermal issues
If the phone throttles, it crawls.
• If the back gets hot during light use, remove case for a while.
• Avoid charging and using games or heavy apps at the same time.
• Old batteries cause slowdowns. If phone is 3+ years old, a battery swap helps, if the phone allows it. -
Home screen and keyboard
• Use a simple launcher, not heavy 3D stuff.
Examples: Nova Launcher, Niagara, Lawnchair.
• Reduce widgets on home screen. Weather and news widgets can wake the phone a lot.
• Try a different keyboard.
Gboard or SwiftKey are fine, but turn off:
• Haptic on every key
• Fancy themes
• Stickers and GIF suggestions
Clear keyboard cache in Settings > Apps > Your keyboard > Storage > Clear cache if it lags while typing. -
Check for malware or shady apps
Look for:
• Apps you do not remember installing.
• Apps with no icon in drawer but listed in Settings > Apps.
Uninstall those.
Avoid APKs from random sites. -
Disable or uninstall bloat
On some brands the preinstalled stuff hurts speed.
In Settings > Apps:
Disable things like “Theme store”, “Game Center”, “App lock” if you never use them.
Do not touch core system apps or anything you do not recognize. -
Last resort steps
• Backup photos and files to cloud or PC.
• Factory reset from Settings > System > Reset > Erase all data.
After reset:
• Install apps slowly. Start with essentials.
• Avoid installing 20 social and shopping apps at once.
• Keep an eye on when lag starts again. That usually points to the problem app.
If you share your phone model, Android version, and how much free storage you have, people here can give more specific steps.
@yozora covered most of the sane stuff, so I’ll try not to repeat the same checklist.
A few extra angles that actually made a big difference on my own sluggish Android:
- Disable extra battery savers & “performance” modes
Some brands (Xiaomi, Samsung, Realme, etc.) pile on their own battery / performance managers on top of Android. Ironically, they can make the phone feel slower.
- Settings > Battery / Device care / Performance
- If you see “Ultra power saving,” “Super battery,” “Performance profile,” etc., set it to “Balanced” or “Performance,” at least while you’re using the phone heavily.
Over-aggressive saving can keep apps half-frozen so every switch feels laggy.
- Turn off “Digital Wellbeing” & usage trackers (as a test)
This one I actually disagree with a lot of guides on, because they just ignore it. Digital Wellbeing / Screen Time can cause stutter on some low or mid-range phones.
- Settings > Digital Wellbeing & parental controls
- Temporarily disable app timers, focus modes, parental stuff
- If your brand has its own “usage statistics” app, disable or force stop it and see if the lag improves
- Widget & notification spam cleanup
Not just “reduce widgets” like @yozora said, but specifically:
- Remove live weather widgets that constantly refresh
- Remove news / stock / crypto ticker widgets
- In Settings > Notifications, turn off notifications for noisy apps you don’t care about (shopping, random games, “deal” apps).
Every push notification wakes the device, and too many can absolutely contribute to lag over time.
- Check autofill & clipboard services
Keyboard lag is not always the keyboard. Two usual suspects:
- Password managers with “autofill on every field”
- Clipboard managers / translators that pop up over the keyboard
Try disabling autofill service: - Settings > System > Language & input > Autofill service
Switch to “None” or Google, test if typing becomes smoother.
Also uninstall or disable any floating translator / clipboard bubbles and see if that helps.
- Turn off animations plus live wallpaper
Tuning anim scales helps, but on some cheaper GPUs the live wallpaper is the real performance killer.
- Long press home screen > Wallpaper
- Use a static, dark image instead of live or video wallpaper
This won’t make your phone a rocket, but it can shave off that tiny delay that makes everything feel sluggish.
- Storage type bottleneck (old or low-end phones)
If your phone is older or a budget model, the internal storage itself may just be slow, especially when almost full. Workarounds:
- Move heavy apps (big games, media apps) to SD card only if the SD card is fast and formatted as internal. A cheap slow SD makes it worse.
- Keep big offline maps, Spotify downloads, Netflix downloads on SD and free up internal storage for the system.
- Check for auto backup / sync storms
When backups are running constantly, everything lags. Look at:
- Google Photos backup: open Photos > profile icon > Photos settings > Backup > pause backup for a while.
- WhatsApp / Telegram: turn off super-frequent cloud backups or move chat backup schedule to a time you rarely use the phone.
- Cloud drive apps (Drive, OneDrive, Dropbox) that constantly sync large folders.
- Look at “Accessibility” services
Accessibility tools can hook deeply into the UI:
- Settings > Accessibility
If you see services enabled for apps like screen recorders, button remappers, auto-clickers, themes, “gesture enhancers,” etc., try turning them off one by one and testing performance. Some of these quietly eat CPU 24/7.
- Don’t blindly use “Update all”
Here’s where I’ll slightly disagree with @yozora: on older or budget phones, newer versions of some big apps are heavier. I’ve personally had:
- Newer versions of Instagram / Chrome / YouTube perform worse on a 3+ year old budget phone
If things got bad “over the last few weeks,” check Play Store: - Go to My apps & games > Manage
- Sort by “Recently updated”
If the slowdown lines up with a particular app update, try uninstalling updates for that app: - Settings > Apps > [App] > three dots > Uninstall updates (if available)
- If you do a factory reset, change your habits
If you ever go for the nuclear option:
- After reset, use the phone for a full day with no automatic restore from backup
- Install only: messaging, browser, one social app, banking, and your keyboard
- Use it like that for a day. If it’s fast, start adding apps in small batches and pay attention to when it starts feeling sticky again.
The first batch that makes it lag usually contains the problem app.
If you can share:
- Phone model
- Android version
- Free storage percentage
- Whether it gets hot during normal use
people can probably zero in on whether this is fixable by settings, or if your hardware is just hitting its limits.
