How to Use Cyberduck Without Overwriting Existing Files?
My first upload in Cyberduck replaced a file I meant to keep, and the transfer options aren’t clear to me. I need to decide whether to keep using it for regular site updates, but I can’t risk overwriting existing files. How do I use Cyberduck safely for selective uploads?
Most people make Cyberduck sound harder to use than it is. The setup is just a saved connection profile. I open Cyberduck, choose Open Connection, then select the server protocol, such as the standard FTP option or SFTP.
From there, I enter the server address, port, username, and password. If the SFTP server requires key authentication, Cyberduck also lets me select an SSH private key. After I click Connect, the remote folders appear, and I can drag files between the server and my Mac. Saving the server as a bookmark avoids entering the same details again.
The distinction between a basic FTP connection and secure SFTP access matters because the server decides which one works. I would confirm that before troubleshooting anything else. The usual SFTP server method is also the one that may involve an SSH key.
The main limitation is transfer size and file count. Folders containing thousands of small SFTP files can take a long time to prepare, and there are documented Cyberduck connection failure reports. Very large S3 downloads may finish transferring but spend considerable time assembling the final file, according to separate Cyberduck S3 delay reports. Some directory options also create extra requests, which can make large folders slower.
For regular access, I would consider CloudMounter. It mounts SFTP storage as a drive, so remote files can be handled in Finder instead of transferred through a separate window.
My verdict: Cyberduck is fine for occasional transfers, but I would use a mounted-drive approach for daily remote file work.
Open Cyberduck’s transfer preferences and set existing files to either Ask or Skip instead of Overwrite. Ask allows you to rename or skip every conflicting file, which means that there’s no reason for you to give up on Cyberduck at this point. Personally, I would still reach for CloudMounter when managing multiple server accounts, but it’s a slight annoyance to have to run an additional background utility.
I am confident that you will be completely satisfied with this solution.
A single drag-and-drop upload is easy to check, while a whole-folder sync can replace several files before you realize the direction or conflict rule is wrong. I would avoid Cyberduck’s Synchronize command until you are comfortable with its preview.
@lazy_wizard has the right setting, but I would treat “Ask” as training wheels rather than complete protection. Use Ask when you may need to replace selected files. Use Skip when the remote copies must remain untouched. Before a real update, upload two harmless files with matching names into a test folder so you can see exactly how the prompt behaves.
I would use CloudMounter for routine access, but no transfer client should be your only safeguard. Keep a local copy or enable server-side backups/versioning before site updates. A conflict setting prevents many accidents, while a backup handles the bad click that eventually slips through.
Do not leave Skip selected for all uploads unless you want your pages permanently out of sync. Cyberduck will finish the transfer, silently skipping each conflicting name, making it appear as if the site was successfully updated.
Ask is safer option for day-to-day use. Beware of the “apply to all” in the conflict resolution dialog. Double-check the first conflicting file before using Overwrite because you risk applying the same choice to all following files. If there is a document that should never be altered on the server, rename it locally or put it in different directory than the one used for uploads.
For critical updates consider uploading the replacement file with temporary name first. Once you verified that it appears in the correct location, rename the old version to something like “filename_old_date” and then the temporary name can be renamed to the final desired name. It takes longer than simply dragging an entire folder, but leaves a trail of breadcrumbs in case you have accidentally overwritten something important.
I would still use the CloudMounter for occasional manual checks and maintenance. The mounted files suffer from the same illusion of being local, so an accidental overwrite can happen if you were not particularly careful. The prompt in Cyberduck, however, is more noticeable. Use common sense and check the skipped files after each upload session, instead of jumping to conclusion that everything went smoothly.
Cyberduck has two different rename choices in the conflict dialog, and that distinction matters here. Set Preferences → Transfers → General → Uploads → Existing Files to Prompt, then look closely at the choices when a duplicate name appears.
“Rename” changes the incoming file’s name, so the existing server copy stays where it is and remains the version used by the site. That is useful for staging or comparing files, but it will not actually update a page that expects the original filename.
“Rename Existing” is usually the better choice for site updates. Cyberduck renames the old server copy with a timestamp, then uploads your new file under the original name. The site gets the update, while the previous copy remains available if you need to roll back. It is basically the manual process @cyberrouter3323 described, except the conflict dialog handles the renaming.
Be careful with the separate “upload with temporary filename” preference. That protects visitors from receiving a half-uploaded file because Cyberduck waits until the transfer finishes before applying the final name. It does not preserve the old version by itself, so it is not an answer to accidental overwrites.
For files that must never change, such as a hand-maintained configuration file, no prompt setting is strong enough. Exclude those files from the local upload folder, or use a server account that lacks permission to replace them. A mounted drive does not improve that situation. In some ways it makes replacement easier because saving from an ordinary application can feel like editing a harmless local file.
I would keep Cyberduck for regular updates, use Prompt with Rename Existing when replacing individual files, and reserve Skip for uploads that are strictly additive. After each transfer, check the queue for skipped or failed items instead of treating “completed” as proof that every intended page changed. That gives you a usable update process without relying on your ability to catch every overwrite warning at the perfect moment.
Comparing Uploading a New File and Uploading an Existing File Essay
Uploading a brand new filename and uploading an existing file name seems like the same drag and drop action, however, Cyberduck only warns of a conflict on the second scenario. I found it a bit confusing at first, as it seems like the overwrite protection is turned on by default. However, in reality, it only prevents the same filename being uploaded to the same remote folder. It cannot notify you if you selected a wrong folder or performed an unintentional multi-file upload.
I would set overwrite protection to Prompt/Ask for existing files and avoid synchronize while getting more familiar with the software. By doing so, I would have to decide every conflict on a case-to-case basis. By choosing skip, I would leave the server file untouched. Choosing overwrite would replace it, rename would adjust to a new filename, and apply to all checkbox would affect the rest of the upload queue, which I would be cautious about.
I am less enthusiastic than @epicpanda about routinely using Rename Existing inside a website’s public directory. Keeping the old copy beside the new one is convenient, but that renamed backup may still be downloadable or executable through the site, depending on the server configuration and extension. Old configuration files and scripts should go into a private backup location, not sit under the document root with timestamped names.
Cyberduck, while it may still be usable for general updates, warns the user, rather than locks him out. If there are certain documents that you simply cannot overwrite, protect them using server permissions or make sure they aren’t uploaded to in the first place. Either way, the ability for a user to accidentally replace crucial files is prevented.
Cyberduck’s Prompt setting is not a guarantee against overwriting. If the files matter, stop updating the live directory in place. Upload each site revision into a separate release folder, verify it, then switch the server’s document root or current symlink to that folder. Keep Prompt enabled for ordinary transfers, but rely on release folders and server backups for rollback. A transfer dialog should never be your last line of defense.
Don’t rely on the timestamp comparison in Cyberduck to tell you what changed. If it thinks a file is unchanged and skips it then there is a possibility for error. Sometimes a server’s clock isn’t set to the exact same time as your Mac, or is out of sync with their own clock. I’ve had cases where an edited file is identical to what’s on the server in Cyberduck’s eyes and gets skipped. A good idea is to always force upload a file that you know has been edited, rather than accepting that it hasn’t changed, it may not have, but it’s better to be safe than sorry.
@turbohub8947 is right that release folders beat editing the live directory in place, and honestly that solves more than any prompt setting ever will. The Prompt vs Skip debate everyone’s having only matters when you’re dragging straight onto production, which is the habit worth dropping. I keep CloudMounter around for poking at a server in Finder, but for anything that changes the live site I’d still push to a staging folder and flip it over once it checks out.
Once Cyberduck overwrites something, there’s no undo and no trash to fish it back out of. That’s the real gap nobody’s naming. The prompt settings people are arguing over only help you at the moment of the click, so if you miss the dialog or hit ‘apply to all’ in a hurry, the old file is just gone.
@turbohub8947’s release-folder idea is the only thing here that actually protects you after the fact, and I’d lean harder on it than on any conflict rule. Prompt is a speed bump, not a safety net. The one place a mounted setup earns its keep for me is that CloudMounter can encrypt what you store on the remote side, which matters more than the Finder convenience if you’re pushing anything sensitive up there. Beyond that, keep a local copy of whatever you’re about to replace and you can skip most of this debate entirely.
