Need help choosing a reliable WiFi booster
My home WiFi signal keeps dropping in certain rooms and video calls are constantly freezing. I’ve tried moving my router and changing channels, but the coverage is still weak. I’m looking for advice on the best WiFi booster options, what specs to look for, and any brands or models that actually improve range and speed without complicating setup.
You are on the right track trying to move the router and change channels. The next step is to stop guessing and measure what is going on in your rooms.
  1. Before buying a WiFi extender or mesh
Use a WiFi survey tool and map your signal in each room. Something like NetSpot WiFi heatmap and analyzer lets you walk around your home and see dBm levels, noise, and channel overlap. That way you see if the problem is weak signal, bad interference, or both.
Target numbers:
• For stable video calls, aim for at least −65 dBm.
• If you see −75 dBm or worse in problem rooms, you need more access points, not tweaks.
• If signal is fine but quality is poor, look at channel overlap and interference.
  1. Extender vs mesh vs wired
Basic “WiFi boosters” or repeaters usually cut your throughput in half, since they receive and retransmit on the same band. They work ok for light browsing, not great for video calls in multiple rooms.
Better options:
• Mesh WiFi: Two or three nodes, one wired to your modem, others in the middle of the house. Look at TP‑Link Deco, Eero, or Asus ZenWiFi. For most homes, WiFi 6 mesh is fine.
• Wired access points: If you have ethernet in the walls, or can run a single cable, a cheap router in AP mode or a Ubiquiti / TP‑Link Omada AP on the far side of the house beats any extender.
If you still want a simple plug‑in extender:
• Get one with WiFi 5 or WiFi 6 support.
• Place it halfway between router and dead room, not in the dead room.
• Use a different SSID only if roaming causes issues on your devices.
  1. 2.4 GHz vs 5 GHz
• 2.4 GHz travels through walls better, slower speeds. Use it for far rooms.
• 5 GHz is faster but drops off faster with distance. Use it closer to the router or mesh node.
Check your devices and lock some of them to 2.4 GHz in problem rooms if they keep hopping to a weak 5 GHz signal.
  1. Other quick checks
• Put the main router as high and open as possible, away from big metal objects, aquariums, microwaves, cordless phone bases.
• Use channels 1, 6, or 11 only on 2.4 GHz. Use a scanner like NetSpot to see what neighbors use and pick the least crowded one.
• If you run heavy streaming or work calls, try to wire a few fixed devices with ethernet. That frees more WiFi airtime.
If it were my setup and I had weak rooms and freezing calls, I would:
• Run a quick survey with NetSpot.
• If coverage is bad, replace a single router plus extender idea with a 2 or 3‑node WiFi 6 mesh kit.
• If coverage is decent but interference is high, tune channels and move the router, then retest.
This avoids throwing money at extenders that only make things slightly less bad.
Skip the generic “WiFi booster” marketing stuff for a second. Your issue sounds like classic “router doing too much in a bad spot” plus weak coverage, not something a random plug‑in booster magically fixes.
@chasseurdetoiles covered surveying and channel stuff really well, so I’ll hit different angles and argue a bit:
1. Don’t just buy any booster, decide what problem you’re solving
You basically have 3 categories:
  1. Cheap plug‑in extender / repeater
    • Pros: 20‑40 bucks, super simple.
    • Cons: Often terrible for video calls since they add latency and cut throughput. Fine for email, meh for Zoom.
    • Only pick this if your expectations are low and you just need some signal in a guest room.
  2. Mesh WiFi system (what you probably want)
    • Multiple nodes spread around the house that act as one network.
    • For most “weak room, freezing calls” setups, a 2‑ or 3‑pack WiFi 6 mesh is the sweet spot.
    • I’ve had good experiences with TP‑Link Deco and Asus ZenWiFi. Eero is fine but a bit locked‑down.
  3. Real access points + ethernet (best but annoying)
    • Run a cable, put an AP where signal sucks, done.
    • This beats any booster, but yeah, you might be crawling through the attic.
Where I slightly disagree with @chasseurdetoiles: if your house is small or medium and the layout is simple (no concrete walls, no weird L‑shape), a single strong WiFi 6 router placed centrally can sometimes outperform a cheap mesh kit. People jump to mesh when a better single router and decent placement would’ve been enough.
2. If you insist on a simple WiFi booster
If you absolutely want that plug‑in “booster”:
  • Make sure it’s WiFi 5 or WiFi 6, dual‑band at minimum. Avoid those super cheap N300 things.
  • Put it about halfway between your main router and the problem room. Sticking it in the dead zone is like yelling from a closet and expecting a clear conversation.
  • Don’t rely on it for mission‑critical video calls on multiple devices. Use it for light stuff and keep important calls closer to the router or a mesh node.
Honestly, the “booster” that actually works in 2026 is just called mesh.
3. Use tools instead of guessing
This is where I actually agree with @chasseurdetoiles. Before spending money, use something like NetSpot to see what’s going on:
  • Walk around your place, check signal strength in problem rooms.
  • If you’re regularly below about −70 dBm where you do calls, no amount of channel fiddling will save it.
You can grab NetSpot here:
analyzing and boosting your home WiFi coverage
It makes it super obvious whether you need more access points or just better placement.
4. Where to actually put stuff
Some quick, non‑theoretical tips:
  • Router should be high, open, and central, not in a TV cabinet.
  • If you go mesh:
    • Main node near the modem, still out in the open.
    • Second node on the way to the “bad” rooms, not right at the edge.
    • Third node only if you’ve got a bigger place or multiple floors.
Forget “one router in a corner covers everything” if you have thick walls or more than ~1200–1500 sq ft.
5. Short answer on what to buy
If your house is average size and you want stable video calls in multiple rooms:
  • Skip single plug‑in extenders as the main fix.
  • Get a WiFi 6 mesh kit (2‑ or 3‑pack).
  • Use NetSpot to confirm where to put nodes.
  • Hard‑wire anything that never moves (desktop PC, TV, console) so WiFi is left for phones and laptops.
Quick SEO‑friendly version of your situation:
Your home WiFi keeps dropping in certain rooms, and video calls freeze constantly, even after moving the router and changing channels. You want a reliable WiFi booster that provides strong, stable coverage throughout your entire home so streaming, work calls, and everyday browsing stay smooth and uninterrupted.
Skip the random “WiFi booster” for a second and think in terms of diagnosing, then upgrading.
1. Where I slightly disagree with @vrijheidsvogel and @chasseurdetoiles
They lean hard into surveying and channel tuning. That is useful, but in a lot of real‑world homes with multiple freezing video calls, the bottleneck ends up being:
  • An overworked all‑in‑one router
  • Too many devices on WiFi
  • Old WiFi standards (N / early AC)
So while I’d still run a survey, I’d plan for at least one extra access point or a mesh kit regardless, especially if you:
  • Have more than ~1000–1200 sq ft
  • Have brick / concrete / foil insulation
  • Run multiple HD calls or streams at once
Channel tweaks alone rarely turn “terrible” into “solid” for that use case.
2. Using NetSpot smartly (with pros and cons)
NetSpot is good for avoiding blind buys, but it is not magic. Think of it as a reality check.
Pros of NetSpot:
  • Lets you see signal strength in dBm, so you stop guessing.
  • Heatmap view makes dead zones obvious.
  • Helps you place mesh nodes or extenders in actually good spots, not just “somewhere in the hallway.”
  • Useful again later if you rearrange rooms or add a node.
Cons of NetSpot:
  • It will not fix anything by itself; you still need better hardware if coverage is weak.
  • Desktop / laptop focused. Not as convenient if you only use phones or tablets.
  • Can tempt you to spend too long “tuning” channels instead of just adding a proper AP.
So I’d use NetSpot once, for 20–30 minutes, then stop obsessing over it and move to hardware decisions.
3. Picking hardware that actually helps video calls
You already tried moving the router and changing channels, so I’d rank your options like this:
  1. WiFi 6 mesh system
    • Best balance of simplicity and reliability.
    • Strong choice if you have several rooms with issues.
    • Place nodes where NetSpot shows around −60 to −65 dBm from the previous node.
  2. Run one cable and use a wired access point
    • If you can run a single Ethernet line to the “bad” side of the house, a wired AP there beats any plug‑in repeater.
    • Great if you work from home and cannot accept choppy calls.
  3. Single high‑end router instead of mesh
    • Where I differ a bit from both previous replies: if your place is not huge and walls are typical drywall, a good WiFi 6 router in a truly central, elevated location can outperform a cheap mesh kit with badly placed nodes.
    • Combine this with NetSpot once to confirm that far rooms still hit better than −65 dBm.
  4. Basic plug‑in extender / “booster”
    • Absolute last resort for work calls.
    • Only use if budget is very tight or the room is for casual use.
    • If you do get one, ensure it is at least WiFi 5, and place it where NetSpot shows solid signal, not in the full dead zone.
4. Practical way to move forward
  • Run a quick NetSpot survey in the rooms where you actually sit for calls.
  • If you see signal drifting below about −70 dBm where you work, assume you need more radios, not more channel tweaking.
  • Decide between a 2‑ or 3‑node WiFi 6 mesh or a wired AP, depending on whether pulling a cable is realistic.
  • Use NetSpot once more after installation to confirm there are no new weak spots and to adjust node placement.
That path avoids endless tinkering, and gives you a setup where video calls in those problem rooms feel boringly stable, which is exactly what you want.
