I’m working on a small app and I’m struggling to get simple, genuine user reviews that don’t sound fake or forced. I’m not sure what to ask users, how to prompt them in-app, or what timing and wording works best to encourage quick, honest feedback. Can anyone share practical tips, examples, or best practices for getting more high-quality app reviews without annoying users?
Short version. You want honest reviews. You need three things. Right timing, simple prompts, low friction.
Here is what has worked for me on small apps.
Ask at the right moment
- Trigger after a clear success event.
- Finished a task.
- Got value from a feature.
- Hit a small milestone.
- Example triggers
- After user completes 3 sessions.
- After user uses feature X 5 times.
- After they return on day 3 or day 7.
- Avoid first session and avoid right after signup or onboarding. Feedback is weaker there.
Start with a 2-step flow
Step 1 in‑app:- Show a small modal.
- Question:
- “How is [AppName] working for you so far” with 1–5 stars.
- Make it easy to skip: “Not now” button.
Logic:
- If 4–5 stars:
- Show: “Thanks. Mind rating us in the store” with a “Rate in store” button.
- If 1–3 stars:
- Show: “Thanks for the honesty. What should we improve first”
- Free text box.
- Optional email field: “If you want a reply, drop your email.”
This keeps bad experiences inside the app as feedback. Good ones go to the store.
Use simple, natural wording
Avoid marketing tone. Avoid “We value your feedback” etc. Use language like you talk.Examples that feel human:
- “Is [AppName] helping you so far”
- “What is one thing you like”
- “What is one thing you would change”
- “Anything bugging you”
For follow‑up email (if you use email):
- Subject: “Quick favor about [AppName]”
- Body:
- “Hey,
You used [AppName] a few times.
I am trying to make it better.
Could you tell me what works and what sucks
One or two sentences is perfect.
Reply here or tap this link to rate in the store.
Thanks,
[Name]”
- “Hey,
Keep it short. Do not sound like a brand deck.
Give them a starting point
Many users freeze when the question is too open.Use one or two small prompts:
- “If you had to explain [AppName] to a friend in one sentence, what would you say”
- “What do you use it for most”
- “How does it compare to what you used before”
You then see phrases you can re‑use and you get natural language.
Reduce friction to almost zero
- One tap rating in app.
- Optional text, not required.
- No forced login for rating.
- Store review link goes straight to the store review screen, not the app page.
Ask at the right frequency
- If user taps “Not now”, wait.
- Example: retry after 5–7 days of active use or 5–10 sessions.
- If user leaves a store review, stop asking.
- If user gives low rating and feedback, only ask again after you ship fixes and after some time.
Use data to tune it
- Track:
- How many see the prompt.
- How many tap a star.
- How many go to store.
- How many submit store reviews.
- If almost no one interacts, your prompt timing or copy is off.
- If many tap 4–5 stars but few store reviews, you push too late in the flow or store redirect is annoying.
Rough numbers I see in small apps:
- 20–40 percent interaction rate with a simple in‑app star prompt.
- 20–50 percent of happy users accept to go to store.
- Some drop off in the store, of course.
- Track:
Encourage honesty directly
The fastest way to avoid fake‑sounding reviews is to say it.Example text:
- “Honest reviews help a lot, even if it is not 5 stars.”
- “Say what works and what does not. Short is fine.”
You will get more 4 star reviews with detail. Those help more for conversions than a wall of 5 star “Great app” posts.
Seed with early users
If you have any friendly or beta users:- DM or email them personally.
- Example:
- “Hey [Name],
I pushed a public version of [AppName].
If you have 30 seconds, a short honest review in the store would help.
Does not need to be positive, I use it to plan what to fix next.”
- “Hey [Name],
If you treat it like a favor, you get fewer fake‑sounding “love this app!!!” type reviews.
Do not over‑optimize the rating
If you push too hard for 5 stars, users smell it and reviews look fake.
Things to avoid:
- “If you love us, rate 5 stars, if not, email us.”
- Overly cheerful copy.
- Huge popups at launch.
- Blocking use behind feedback modals.
Quick template you can steal for in‑app:
Step 1 prompt:
Title: “How is [AppName] working for you”
Body: “Tap a star to rate it. Honest feedback helps a lot.”
Buttons: [1–5 stars] [Not now]
If 4–5:
Title: “Thanks, this helps.”
Body: “Would you post this rating in the app store so others see it”
Buttons: [Rate in store] [No thanks]
If 1–3:
Title: “Thanks for telling me.”
Body: “What should I fix or improve first”
Field: Free text
Buttons: [Send feedback] [Skip]
Run that for two weeks, look at the numbers, then tweak timing and wording.
You’re already on the right track looking at what @nachtdromer wrote. Their system is solid. I’ll add some stuff from a slightly different angle and push back on a couple of points.
1. Don’t rely only on “success events”
Yes, triggering after a win is smart, but if you only ask after happy moments, your reviews skew weirdly positive and can still feel fake. Mix in:
- A “been around a while” trigger: e.g. first review prompt after 10 days of calendar time, not just when they do X actions.
- A “quiet moment” trigger: when they open the app and just land on the home screen, not mid‑flow. Some people only use your app for one thing and never hit your “milestone,” but they still have clear opinions.
That gives you more “this app is okay, here’s what I like / hate” reviews instead of just “amazing!!” after a dopamine spike.
2. Ask one very concrete question
Where a lot of people mess up is with vague “How can we improve?” stuff. Instead, rotate 1 fast, specific question like:
- “What’s one thing that annoys you when you use this app?”
- “If we removed one feature, which one would you not miss?”
- “What do you actually open this app for most of the time?”
Then follow with:
“Want to share that as a review so others see it?” → link to store.
This turns their thought into a review template. Many users will literally copy‑paste or paraphrase.
3. Show them an example, but not a script
I kinda disagree with fully open text and no guidance. People blank.
Instead, somewhere in the dialog:
“Short is perfect. Example: ‘I use it for ___ and wish it did ___ better.’”
You’re not ghostwriting their review, just giving a shape. The result is still way more natural than those auto‑generated sounding “Amazing app, does exactly what it says” clones.
4. Treat critical users as your “review gold”
Most folks obsess over funneling only 4–5 star users to the store. That’s fine for rating averages, but a wall of 5-star “love this app” does look fake.
Let some 3-star people through on purpose, especially if their feedback is specific:
- In‑app: “Thanks for being honest. Want to post this as a store review so other people see the pros and cons?”
- If they say yes, send them with their own text pre-filled if the platform supports it or remind them: “Mention what you like and what’s missing.”
Specific 3–4 star reviews like “Great idea, missing X and Y” make you look real and trustworthy.
5. Use your release notes as review magnets
Most devs waste the “What’s new” section. Use it to nudge quietly:
- “If this update fixed something that annoyed you, a short honest review helps more than you’d think.”
- “If this update broke something, tell us in the app before you roast us in the store
You’re catching people who just interacted with your app because of an update and already have an opinion.
6. Turn support convos into reviews organically
Any time someone emails or messages you like:
“This is really helpful, thanks” or “This solved my problem”
You answer, then add:
“If you don’t mind dropping a short honest review in the store, that kind of thing helps a lot more than you’d expect. Even 2–3 sentences.”
Don’t send them a script. Don’t push for 5 stars. Just ask after you provided visible value. These reviews are usually super natural: “Support replied fast, fixed my bug, app works fine now.”
7. Make the tone match your app’s personality
Where I’d tweak @nachtdromer’s advice: their copy is nicely neutral. If your app has a particular vibe, lean into it a bit.
Examples:
- Productivity app: “Mind telling us what works and what’s slowing you down?”
- Fitness app: “Is this actually helping you move more or just another app on your phone?”
- Habit app: “What’s one thing we should fix so you actually keep using this?”
You want users to feel like they’re talking to the same “voice” they see inside the product, not a corporate PR form.
8. Pay attention to who you’re asking, not just when
User segments matter more than people think:
- Power users: fewer prompts, but more open‑ended questions. Their reviews are detailed.
- Casual users: super short, almost yes/no + “add a sentence.”
- New but engaged: ask sooner, they still remember their first impression.
Even a simple rule like “do not ask someone who just finished a rage‑inducing error flow” saves you a lot of 1‑star “app broken” spam.
9. Don’t chase “perfect sounding” reviews
The ugly truth: natural reviews will have typos, weird phrasing, and half-finished thoughts. That’s what makes them feel real.
If your reviews all read like “I have been using this application for several weeks and it has significantly improved my workflow”… yeah, that smells like you’re over‑engineering the funnel.
Aim for:
- Short, slightly messy
- Specific (“use it to track invoices”, “use it for meditation at night”)
- Mixed tone (“love X, hate Y”)
Those convert way better than pristine fluff.
If you wire things up so people can vent easily, praise easily, and you’re occasionally nudging both types toward the store, you’ll end up with exactly the kind of honest, non-forced review set you’re looking for.
You’re overfocusing on where to ask and how many steps the flow has. Timing & 2‑step logic are solid, but there’s a missing layer: shaping what people actually write without making it sound staged.
Think of it like UX for words.
1. Don’t ask “for a review,” ask for a story
Instead of “Please leave a review,” try variations like:
- “What were you using before this, and why did you switch?”
- “Tell us about the last time this app actually helped you.”
People answer in narrative form by default. Those answers naturally turn into:
“I used to track X in Sheets, now I use this app because…”
which reads 100x more real than “Great app, 5 stars.”
You can then follow up with:
“Do you mind copying a sentence or two of that into a store review so others see it?”
This is where I mildly disagree with both @chasseurdetoiles and @nachtdromer: they lean more on short, generic prompts. Good for conversion, not always great for texture.
2. Use contrast questions
To avoid bland “works well” reviews, ask things that force specificity:
- “What surprised you, good or bad, after using it for a week?”
- “What did you expect this app to do that it doesn’t?”
Honest contrast reviews sound like:
“I thought it would be annoying to set up, but it was quick. Still missing offline mode.”
That tension makes reviews believable.
3. Add a “rough notes first” mini surface
Micro trick: add a tiny link like:
“Jot rough thoughts (we’ll tidy nothing).”
Let them type messy bullets. Don’t auto‑clean or overformat. When you later nudge them to leave a public review, explicitly say:
“Copy any part of what you wrote, typos and all. Real is more useful than perfect.”
Polished language reads like marketing; raw notes read like a human.
4. Make the app feel like a small project, not a faceless product
You want reviews that read like someone helping a small builder, not performing for a brand.
Subtle copy shifts:
- Instead of: “Your review helps other users discover [AppName].”
- Try: “I read every review to decide what to build next. Say it exactly how you’d tell a friend.”
Address from a person, not “the team.” This is where a product title like AppName actually works in your favor for SEO: it becomes part of a sentence that sounds human, e.g. “If you describe how you actually use AppName, that’s gold.”
Pros of doing this:
- You get detailed, specific reviews full of real phrases future users search for.
- Lower chance of “bot” vibes, even if all reviews are positive.
- Helps you discover positioning language directly from users.
- Fewer total reviews than a hyper‑optimized “only show store link to 5‑star users” funnel.
- More 3–4 star reviews that mention flaws. Your average might drop a bit, but conversion from readers usually goes up.
5. Rotate question “themes” instead of repeating the same prompt
Instead of always asking “How is [AppName] working for you?” rotate weekly or by cohort:
- Week 1 cohort: “What made you try this instead of other apps?”
- Week 2 cohort: “What do you actually use this for most of the time?”
- Week 3 cohort: “What almost made you stop using it?”
You avoid a wall of identical phrasing in reviews, which is one of the biggest “this feels fake” signals.
6. Be explicit about what not to write
Lightly steer away from generic praise:
“You don’t need to write ‘best app ever.’
Just say what you use it for and what still annoys you.”
Counterintuitive, but giving people permission to complain a bit makes the positive parts more believable.
So in short: @chasseurdetoiles and @nachtdromer covered when and where really well. Layer on how to pull stories instead of adjectives and you’ll get reviews that look like real humans venting and praising, not like a promo reel.
