Need help finding deleted photos on iPhone
I accidentally deleted some important photos from my iPhone. I’ve already checked the ‘Recently Deleted’ folder, but they aren’t there. What other options do I have to recover these photos? Any advice would be greatly appreciated!
It looks like you’ve already tried the ‘Recently Deleted’ folder without any luck. Here are a few other ideas you could try:
  1. iCloud Backup: Check if you’ve backed up your photos to iCloud recently. If so, you can restore your iPhone from an iCloud backup.
  2. iTunes Backup: If you’ve backed up your iPhone to your computer using iTunes or Finder, you might have a backup that contains your deleted photos. You can restore your iPhone from one of these backups to retrieve your lost photos.
  3. Third-Party Software: Consider using recovery apps like Disk Drill. They are designed to recover lost data from iOS devices. It’s quite effective for many users in similar situations.
  4. Professional Help: If the photos are extremely important, you might want to consider professional data recovery services. They can be expensive but sometimes have higher success rates.
Here’s a detailed guide on how to undelete photos on your iPhone and fix accidental deletions in minutes: How to Undelete Photos on iPhone.
I hope one of these methods work for you! Good luck!
If the ‘Recently Deleted’ folder didn’t work, peer into these possibilities:
iCloud Photo Library: If you use iCloud Photo Library, visit iCloud.com and check the Photos section. Sometimes photos might be synced to the cloud even if they vanish from your device.
Photos Recovery from Email or Messaging Apps: Important photos might have been shared through emails or messaging apps. Searching through email attachments or app archives could yield results.
Photo Apps with Recycle Bins: Some third-party photo management apps include their backup or recycle bin systems. It might be worth it to check if any such apps on your device have the photos stored.
Cloud Storage Services: Services like Google Drive, Dropbox, or OneDrive often sync automatically. They might provide another backup layer you could explore.
While third-party software like Disk Drill could be highly effective, it’s good to remember not all services guarantee success, and they may sometimes house risks or costs. Regarding professional data recovery, that’s a last-resort effort. Usually, it’s pretty expensive without a guaranteed salvage.
Balancing these tips might yield the best result. Try to pinpoint an approach best suited to your next step, and don’t hesitate to experiment with these various methods. Good luck diving into these recovery avenues!
One thing you haven’t tried yet is checking if the photos might be stored in any hidden albums on your iPhone or in folders you normally wouldn’t look into. It’s a long shot, but sometimes photos end up in weird places due to syncing or app mishaps.
Instead of putting all your bets on Disk Drill—though it’s a solid choice with solid pros like its intuitive interface and broad recovery abilities—consider also looking at Dr.Fone or EaseUS MobiSaver. Each comes with their own set of pros and cons.
Dr.Fone, for example, has been quite popular thanks to its user-friendly interface, but it’s not always as robust in finding deeply buried files. EaseUS MobiSaver is another alternative, known for its reliability but also potentially higher costs. Disk Drill does have the advantage of also being able to retrieve other kinds of lost data—not just photos—so keep that in mind if you have other files at risk.
Also, check if you have any automatic backups enabled with cloud services like Google Photos, Dropbox, or OneDrive. Sometimes, these services might have a recent copy of your deleted photos even if they’re gone from your device.
Lastly, make sure to avoid using your iPhone too extensively until you’ve exhausted all recovery options. Further usage might overwrite the data sectors where your deleted photos reside.
Hopefully, one of these approaches works out for you. Nothing beats the annoyance of losing precious photos!
