I’ve blocked out 73 minutes tomorrow to watch the Starship orbital attempt, but I may need to step away during the coverage and want to avoid seeing the result before I can resume. Is there a practical way to follow it with a delay while still keeping the sequence of events intact?
You don’t need to watch it live to keep the sequence intact. Open the YouTube stream before launch, pause it, then resume when you’re ready. Stay off social media and disable news notifications, and don’t refresh the player since that may jump you to the live point or expose the result.
Pausing YouTube is not reliable since a reload, app crash or sleep will return you to live. If you want to avoid spoilers, you can record the stream locally or via a TV/DVR service and watch that file later.
Your phone may spoil it before YouTube does. Disable news and social notifications, hide the live chat, pause the stream, and resume without refreshing the page. For a short interruption that’s probably easier than setting up a recording, though @crystalpixel5095 is right that a saved copy is the only dependable option if you absolutely can’t risk a reload.
Build extra time around the scheduled window, because launch holds can make the neat viewing block much longer. The stream should be started as soon as possible, the device powered on with sleep disabled and put in to full screen before the countdown begins. This eliminates several ways that the result can appear while you are trying to return to your paused spot.
The most easy to miss spoiler source is the YouTube home screen. Don’t look for the stream again if the tab reloads. The recommended videos may immediately show a thumbnail indicating if it launched, scrubbed or failed. Smart TV apps are especially bad for this, as they open up on a recommendation page rather than the paused player.
For a brief absence, I’d leave the stream paused on a laptop in full screen and lock the room rather than the computer. Some systems suspend browser tabs or disconnect video after sleep, even if the page looks intact after. Hide chat before pausing as well, as comments can race ahead of your playback position.
If you have to abandon the session entirely, @0xloop5’s recording approach is the safer route, but pad the recording well past the planned end. With launch coverage, the published schedule is more of an intention than a dependable runtime.
A recording can fail just as quietly as a paused stream: no system audio, a full drive, or a capture that stops when the computer sleeps. Before launch day, make a short test recording with the exact device and software you plan to use, then play the file back. Check the sound, confirm it keeps recording when the browser is minimized, and make sure notification banners are not being burned into the video.
The most practical setup is to use both methods. Pause the YouTube player when you step away, but keep a local recording running underneath. If the paused session survives, resume normally. If YouTube reloads or jumps to live, close it immediately and continue from the recording instead. Prepare the recording folder and media player beforehand so you never have to return to YouTube’s home screen.
If recording is too much hassle, a spoiler-tolerant friend or family member makes a surprisingly effective recovery system. Should the app crash, have them reopen the stream, find roughly where you left off, hide the chat, and hand the device back in full screen. The weak point here is not pausing the video. It is recovering from a failed pause without looking at anything.
Final rewrite:
Honest, the thing you’re trying to avoid could very well happen. You see, Starship has a habit of scrubbing its launches, and if it does, there is absolutely no point in even getting on board in the first place. After all, the only thing you’d be wasting your precious 73 minutes to look at would be a countdown that resets itself.
The buffer limit is what nobody here flagged. YouTube only holds so much of a live stream behind the live edge, and if you pause too long the player quietly drops the oldest part. Come back after a long break and you can find yourself bumped forward or unable to rewind to where you were, even without a reload. So @crystalpixel5095 and @hacker.java’s pause trick works for a bathroom break, not for wandering off for half an hour. For anything longer, the local recording that @lazy_wizard described is the only thing that actually protects you.
I think my method is a bit simpler than the way you have to set it up with dual screens. Just don’t watch the live stream and let it start, maybe wait twenty minutes after the window closes to open up a full replay from the beginning. No buffer or recovery if it crashes and no friend to watch your screen. The only discipline you have to practice is not checking your notifications for the short period of time it is open, which is much easier than watching a paused tab and a background capture at the same time.
Don’t scrub the timeline.
If you pause and come back late, dragging the playhead forward is where you’re most likely to hit a spoiler frame. Resume from your saved position and use faster playback during holds, repeated commentary, and other dead time. Drop back to normal speed when the countdown starts moving again. That lets you recover a decent amount of time without ever jumping to the live edge.
I’d separate your viewing window from the recording window. Let the capture run from well before the scheduled attempt until well after it, even if you only have a limited period to watch. A hold does not necessarily mean you need to spend that entire extra hour staring at the broadcast. Most of it can be compressed later.
Mute notifications at the operating-system level, not just inside individual apps. Calendar alerts, texts mirrored from your phone, email previews, and group chats can all appear over a local recording or paused player. Disconnecting the phone from the computer is cleaner than hunting through every notification setting five minutes before launch.
I disagree slightly with leaving the computer unsecured just to prevent sleep. Screen locking and system sleep are separate settings on most machines. Disable automatic sleep temporarily, keep the laptop plugged in, and lock it when you leave. Test that exact setup with an ordinary livestream first. If locking interrupts playback or capture on your particular machine, you’ll find out before it matters.
The straightforward setup is a paused player plus a recording, with the player treated as disposable. If it reloads, starts playing, or lands somewhere unexpected, close it without trying to rescue the session and use the file. Trying to repair a broken live tab is how you end up staring at a title, thumbnail, chat message, or final vehicle status.
The hidden catch in @jeff’s plan is that the full replay may not be available immediately. Livestream archives sometimes need processing or get trimmed, so “I’ll watch it afterward” can become “I’ll stare at a processing message while avoiding the entire internet.”
If you need to resume on your schedule, record it. If timing does not matter, wait for the official archive rather than babysitting a paused tab.
