Which serial sniffer tool should I use for reliable debugging?
I’m starting to debug a flaky serial connection and realized I need a solid serial sniffer, but I’m overwhelmed by all the options out there. I’m looking for recommendations on the most reliable and user friendly serial sniffing tools for Windows and possibly Linux, ideally with good protocol decoding and logging features. What tools are you using in real world projects, and what made you choose them over others?
For flaky serial links, the “best” sniffer depends on what you need to see and how deep you want to go. Here is what has worked well for me and a few teams I worked with.
  1. Easiest software-only option on Windows
    If you want a GUI, logging, and filters, look at Serial Port Monitor.
    • Clear view of TX/RX in hex and ASCII
    • Can attach to an already open COM port
    • Good for long logs and protocol debugging
    • Works well for RS232, RS485, etc, as long as Windows sees a COM port
If you want an RS232 sniffer tool that is focused on monitoring low level serial traffic, take a look here:
RS232 monitoring and serial data analysis
That one is solid for debugging flaky links where timing and framing errors matter. Logging to file and replay features help a lot when you need to compare good vs bad sessions.
  1. Free or open source options
    If you are ok with less polish:
    • PuTTY or Tera Term for quick manual checks. Simple, but no deep analysis.
    • RealTerm for raw hex views and odd baud setups. UI is rough, but it works.
    • pySerial + a small Python script if you want custom logging or triggers. Good if you script your tests.
  2. Hardware sniffers for tough cases
    If the line drops, or the OS driver hides errors, you need hardware in the middle.
    Look at:
    • Saleae Logic with a UART decoder. Great for timing, glitches, framing errors.
    • Cheap USB logic analyzers with PulseView or Sigrok. Good value, slightly more setup.
    • Inline RS232 tap cables with a second USB to serial adapter. Connect RX from both sides to a separate logger, so you see what each device sends and receives.
  3. What I would pick for your use case
    You said “flaky” and “reliable and user friendly”, so I would start with:
    • Serial Port Monitor on the PC side for quick capture, protocol decoding, and logs.
    • If the issue looks like noise or timing, add a small logic analyzer and watch the same session in hardware.
Quick workflow that helped me more than once:
  1. Use Serial Port Monitor to log a full failing session. Save hex + timestamps.
  2. Log one known good session with the same setup.
  3. Diff the two logs. Look for missing bytes, repeated frames, sudden gaps in timestamps.
  4. If the logs look clean but the device still fails, hook a logic analyzer on TX/RX and check for:
    • Framing errors
    • Baud mismatch
    • Short spikes or noise on the line
This mix of software logging and hardware capture tends to find the root cause faster than swapping tools all day.
For flaky serial links, I’d split your options into “quick sanity checks” vs “actual debugging tools,” and that’s where I slightly disagree with @techchizkid: I don’t think PuTTY / Tera Term / RealTerm really qualify as sniffers. They’re great terminals, but once things get intermittent, you usually need more structured capture and timing info.
Here’s what tends to work well in practice:
1. Software sniffer that doesn’t fight you
If you’re on Windows and want something you can actually live in all day, a dedicated tool like Serial Port Monitor is one of the few that’s both reliable and not a total UI fossil. Main perks for flaky links:
  • Can attach to an already opened COM port, so you don’t have to rewire your existing app.
  • Shows data in hex + ASCII with timestamps that are actually readable.
  • Filters out noise when you just want to see certain directions or patterns.
  • Decent for long captures where you’re waiting for that once-in-20-minutes glitch.
If you’re specifically hunting for a serial port sniffer to trace and log RS232 traffic cleanly, it does that pretty well without having to script your own tooling.
If you want to grab it directly, you can check out
download Serial Port Monitor for advanced serial line debugging
2. When I don’t use it
I wouldn’t bother with it if:
  • You’re doing hardcore electrical noise analysis
  • Or you suspect line-level corruption before the OS even sees bytes
In those cases, software sniffers are just blind. That’s when I agree with @techchizkid: logic analyzers and hardware taps win.
3. Hardware angle, but slightly different priorities
Where I diverge a bit:
  • I’d actually start with a cheap USB logic analyzer + Sigrok/PulseView if you strongly suspect electrical issues, even before messing too much with software tools. You immediately see:
    • Wrong baud / parity
    • Jitter and weird gaps
    • Short spikes caused by bad grounding or EMI
  • Inline tap cables are great, but they can also introduce their own issues if you’re not careful with grounding and load. I’ve seen people “debug” a flaky line by making it worse with a bad tap.
4. Minimal workflow that doesn’t waste your day
If I were in your shoes:
  1. On Windows: install Serial Port Monitor, mirror your current setup, and run a few failing sessions.
  2. Check:
    • Are bytes missing?
    • Are there long timestamp gaps where there shouldn’t be?
    • Are framing / parity errors popping up in the logs?
  3. If the captured stream looks clean but your device still acts possessed, connect a logic analyzer directly to TX/RX and confirm that the electrical signal matches what the sniffer saw.
  4. Only then start changing baud, cabling, termination, etc. Otherwise you just chase ghosts.
Short version:
  • For user friendly, repeatable debugging on a flaky serial link, Serial Port Monitor is a solid primary tool.
  • For suspicious hardware / noise / timing, pair it with a small logic analyzer.
    That combo usually finds the root cause faster than bouncing between ten different serial terminals and hoping one of them “shows more.”
