Why can’t I run my Genboostermark code?
I’m trying to run my Genboostermark code, but it won’t execute correctly and I can’t figure out what’s wrong. I followed the setup steps, checked for syntax errors, and tried running it more than once, but I’m still stuck. I need help troubleshooting why my Genboostermark code won’t run and what I should check next.
Post the exact error text. Without it, people are guessing.
Start with the usual failure points.
  1. Check your runtime version.
    If Genboostermark needs Python 3.10 and you run 3.12, stuff breaks fast. Run:
    python --version
  2. Check install state.
    Run:
    pip show genboostermark
    pip list | findstr genboostermark
  3. Run it from the project folder.
    A lot of code fails because your terminal is in the wrong dir.
  4. Verify env vars.
    If it needs API keys or config values, one missing value kills startup. Print them and make sure they are not empty.
  5. Read the full traceback.
    The first useful line usually tells you the real issue. Import error, missing file, bad path, wrong arg, perms issue.
  6. Try a clean env.
    venv problems waste hrs. Make a new one, reinstall deps, rerun.
  7. Check entry point.
    If you run the wrong file, nothing works. Look for the package docs or pyproject scripts.
If you want help, post:
OS, Python version, install command, run command, full error output, and a small code sample. Otherwise ppl are shooting in the dark.
If you already checked syntax, I’d stop staring at the code for a sec and look at how it’s being launched.
One thing I slightly disagree with @nachtdromer on: a clean env is useful, but I would not jump there first unless the traceback hints at deps. More often the problem is import paths or the module is being run the wrong way.
A few things to check:
  • If it’s a package, try python -m genboostermark instead of running a file directly.
  • Make sure your file is not named the same as the package, like genboostermark.py. That causes hilariously dumb import conflicts.
  • Check for relative imports. Code that works inside an IDE can fail in terminal if the working dir/module context is diff.
  • If it exits instantly with no error, add a few print() lines at startup to see how far it gets.
  • Watch for hidden config files like .env, config.yaml, or JSON settings. Missing file = dead app, no drama, just pain.
  • On Windows, path separators and permissions bite ppl all the time. On Linux/macOS, case sensitivity does.
Also, “won’t execute correctly” is way too vague tbh. “Nothing happens” and “ModuleNotFoundError” are totally diffrent problems. Post the exact traceback and the command you ran, or everybody is just guessing in the dark.
